Thread wires – who uses? - Page 2
Results 21 to 40 of 45
  1. #21
    May 2010
    DENMARK
    4,079
    4126
    12884
    I've never tried thread triangles but I'm wondering how pitch diameter is measured with them. Isn't some kind of reference necessary?
    What range of pitches can one pair of thread triangles cover? The radius at the bottom of each pitch varies.
  2. #22
    May 2007
    2,599
    3054
    479
    Now that's kinda dull. You some kind of paranoid? Or just lack the spirit of adventure?
    A bit careful . Oil field stuff and expensive material.
  3. #23
    May 2007
    2,599
    3054
    479
    Yes they require a reference like the Pee Dee wires do also. They are reasonably prices so I have Pee Dee wires, the triangles, and also had a 0-1 inch thread mics.
    I sold those off. They were very fast to use when I needed them. Mostly mill work and they just are not used.
  4. #24
    May 2010
    DENMARK
    4,079
    4126
    12884
    Quote Originally Posted by Spinit View Post
    By "reference" do you mean the number to be subtracted from the measurement result? I regard that as a constant and each wire diameter has a different constant.
    I'll repeat my question.
    (component) necessary?
  5. #25
    May 2007
    2,599
    3054
    479
    Quote Originally Posted by Gordon B. Clarke View Post
    yes the triangles come with a formula. I never used them as I never needed to. I probably should sell them. They were for someone else to use or for me in a pinch. Just precaution.
    Pee Dee wires come with a formula. It takes into account the wire diameter. I do not have it memorized.
  6. #26
    Feb 2005
    9,457
    15667
    11410
    I like these, though I'm not sure if they are even in business anymore..
    Its basically a thread wire in spring form.. And yes I do use wires on
    occasion, but they are a pain in the ass. These Stupid Ovee gages, you
    just clip them on and measure.. Takes like 2 seconds..
    The main thing is that they are way faster than wires.
    Long thread, you can measure the taper, makes sure its good the
    whole lenght, without messing with wires.
    Plating or a heat treat (if you know the shrink). You know
    EXACTLY where your PD is, and where its going to end up after
    wards.
    Of course you should always check with a thread gage to make
    sure that you will still mate with the other part... Thread form
    and all.
    From this thread years ago when I first found out about these things...
    I've bought a bunch of them on E-bay.. I shouldn't say that because
    now you all are going to go buy them.
    Link ------> Any of you guys use these, OVee spring thread gages?
  7. Likes Spinit, M.B. Naegle liked this post
  8. #27
    May 2005
    Republic of Arizonia
    1,737
    539
    Gordon, if you supply everyone here a free sample, We'll compare wires to your product and give feedback.....
  9. #28
    May 2010
    DENMARK
    4,079
    4126
    12884
    Wires don't usually come with a "formula" although there is a formula that can be used to calculate if a suitable non standard wire is used. Every standard diameter thread wire (3 pcs.) normally has constant that is subtracted from the measurement result.
    This thread has gone way off the OP.
    If the thread isn't a 60 then the constant given doesn't apply.
  10. Likes Nmbmxer liked this post
  11. #29
    May 2010
    DENMARK
    4,079
    4126
    12884
    Quote Originally Posted by JS View Post
    A free sample of what? I just asked a question in the OP and one that has nothing to do with my product
  12. #30
    Jul 2012
    Washington
    3,262
    1323
    1413
    I've never tried thread triangles but I'm wondering how pitch diameter is measured with them. Isn't some kind of reference(component) necessary?
    Mine came from MSC probably 25 years ago. Being "triangles" they each have a different radius on the edges, as in 3 different radiuses. Mine came with a sheet showing the different thread measuring triangle equivalents. They go from #0-80 to 1-1/2-6 TPI for class 2, 2a, 3 and 3a showing basic, min and max pitch diameters. There is also a section showing how to figure out anything not listed from 4 to 80 TPI. Sometimes I hold them to a pair of calipers with some o-rings when I am checking a lot of threads.
  13. #31
    Virginia
    16,248
    7561
    10825
    That can restrict the sense of humour a tad, yes. Certs & liability as they are, I'd want sumthin' a Helluva lot better than thread wires. Calibration-service friendly at that.
  14. #32
    Virginia
    16,248
    7561
    10825
    Quote Originally Posted by Bobw View Post
    Not I. No dust left for them to gather, I have so much s**t already!
    That said, credit is due yah for one of those laughs that isn't usually funny "in real time":
    You don't have to worry if somebody used the ring gage as a die.
  15. #33
    May 2007
    2,599
    3054
    479
    Call it whatever you want. Just buy some triangle gages and use them.
  16. #34
    May 2007
    2,599
    3054
    479
    Me too yet the shop had no way to even check the threads. As long as the shape it true 60 degrees the wires work fine. Most job shops hesitate getting thread mics, groove mics, 24 inch calipers/ verniers. Yet they want it right so when I need something enough I shop and buy it. Thread wires are very accurate.
    It is actually a chart.
    A picture of one. It should be with your Pee Dee wires.
    Pee Dee Thread Measuring Wires | Thread Measuring Wires - LittleMachineShop.com
  17. #35
    Feb 2005
    9,457
    15667
    11410
    Not. Gather dust. That said, credit is due for one of those laughs that isn't usually funny "in real time":
    I am totally confused. What are you trying to say???
  18. Likes Gordon B. Clarke liked this post
  19. #36
    Jan 2019
    Arizona
    1,169
    107
    470
    The most common complaint when measuring with thread wires is holding them and measuring at the same time.
    Mitutoyo (and others) have these types of thread wires (see links) and they fasten to the micrometer anvil and spindle. They can still fall off if not used with care.
    When I visit companies here and in other European countries they are the type I see most often used while I believe in the USA 3 individual wires are more common and of course much cheaper.
    https://shop.mitutoyo.eu/web/mitutoyo/en/mitutoyo/01.02.07.0122/3-Wire%20Thread%20Measuring%20Set/$catalogue/mitutoyoData/PR/313-101/index.xhtml
    64AAA252 Mitutoyo 3-Wire Holder and Thread Wire Set: .225mm Pitch - HigherPrecision.com
    These thread wires can of course be bought individually.
    My question is: How many know and use this type of thread wire?
    I've no idea what happened to the thread title which should read Thread wires - who uses?
    I use thread wires at least a few times a week, one reason to check /calibrate plug gages before we use them, and too double check o.d. threads during 1st articles.
    A thread gage is mainly a fit and function gage and nothing more. it doesnt measure your pd. besides thread gages wear. every thread has and acceptable and unacceptable limit, what you do with that info is owns own business. I take threads pretty serious even shit threads on shit jobs, reason being is that how I started as a machinist was in a thread gage shop.
    mostly I lay the wires on my 2 fingers. before my Prat n whitney super mic took a dump a bunch of years ago we checked them that way it was extremely fast and never lost wires. a adjustable mic stand would be second best unless your confident with the fingers.
    On big parts I use grease and lay a white rag below the part to catch the wires if they fall. I have also used rubber bands to hold the wires on bigger dia parts.
    I dont like anything to hold thread wires together on small parts ( like in the link you showed) reason being is that if wires bind up you will get a bad reading. I want the wires to seat.
    as far as the triangles I wouldn't trust them myself, I know others who do. heres why a round part easier to check accurately with a mic then a flat part.
    Thread mics I just dont like the feel. I have a 0-1" that I bought in the late 80's and used them maybe 2 times.
    1st articles I always use thread wires, gage and optical comparator.
    just my 2 cents everyone has a different view
  20. Likes Gordon B. Clarke liked this post
  21. #37
    May 2010
    DENMARK
    4,079
    4126
    12884
    Quote Originally Posted by DavidScott View Post
    That a triangle has 3 edges is a fact and only common sense and logic that each edge has a different radius. Thanks
  22. #38
    May 2010
    DENMARK
    4,079
    4126
    12884
    Why would I want to do that?
  23. #39
    May 2010
    DENMARK
    4,079
    4126
    12884
    "Helluva lot better than thread wires."?
    What do you think calibration labs use?
    Wires for external and balls for internal.
  24. #40
    Dec 2014
    Arizona
    369
    39
    63
    I use them all the time (without the plastic deals) normally on bastards. The clay/putty works good enough if needed.
    A thread MIC would be nice though.
