Way Lube Oil Dispenser--What Do You Use?
Results 1 to 8 of 8
    Jan 2011
    Kansas
    717
    42
    58
    Default Way Lube Oil Dispenser--What Do You Use?
    How are you all putting/pouring way lube into your machines? I'm looking for something less messy. I've been using a 4 qt measuring can with spout, but it's leaking and I need to replace it.
    Feb 2014
    Sunny South West Florida, USA
    2,772
    10466
    3195
    Our maintenance guys have something that looks like a 1.5 gallon pail with a pump handle and hose. I'll see if I can find similar on grainger or mcmaster and show you an example.
    Feb 2014
    2,772
    10466
    3195
    This looks similar to what they use, but the bucket they put it on isn't a 5 gallon.
    https://www.mscdirect.com/product/details/48552467
    Sep 2002
    People's Republic
    3,003
    216
    2070
    I bought some valve/nozzles that fit on a 1 gallon or 5 gallon pail
    bought from US plastics but this comes up faster
    DYNALON Polyethylene'/'Polypropylene, Faucet - 3UDG9'|'405654 - Grainger!
    Apr 2005
    Beaverdam, Virginia
    7,354
    644
    3463
    Why do a lot of machine builders put those way lube reservoirs in areas that makes them hard to fill? That is one good thing I can say about Star Screw Machines, the lube reservoirs on the machines I ran always were out in the open and easy to fill without making a mess. I have one on an old Takisawa TC-1 that is recessed into a cover and has next to no clearance around it, the cover would be a PITA to remove and replace. It also has a fine screen inside so it has to be filled slowly or the flow will back up. I use a long funnel that has a flexible spout. I think 25% of the lube gets in the tank the other 75% on the floor.
  6. Likes Garwood, Ox liked this post
    Jul 2008
    Milverton, Ontario, Canada
    605
    164
    251
    Quote Originally Posted by TeachMePlease View Post
    Exactly what I use, even for refilling hand oilers and hydraulic tanks. I have one for each pail of oil type.
    No more spills, and can get in nasty locations with it.
    Oct 2014
    CANADA
    Ontario
    137
    54
    I use a little 5 liter plastic gas can. Good enough for me.
  9. #8
    Dec 2018
    Arizona
    19
    13
    Used the use one of these at the last place I worked. Worked good and pretty cheap.
    Siphon Manual Hand Liquid Transfer Pump
    Sent from my SM-N960U using Tapatalk
