Mark W. Ingalls
- Jun 5, 2012
- Little Rock
I'd be more in the $100+ category on these. With 0-80 and 2-56 tapped holes, there is likely some level of careful hand work involved. Are you saying that you personally are making these? If so, you should be able to assign your cost based on your production rate, and whatever financial factors exist for the situation.
I would say around $50-60 each for up to 10.
So.. .065" diameter, .059 deep ±half a thou, and then in the same hole, .078" diameter .0565±.0005 deep?
I'd like to see the equipment that can measure that step, .0025 deep, .007 wide. Down in a tiny little hole.
I bet you don't have it, I don't have it, and I bet your customer doesn't either.
Loosen up on some of the dumb stuff and I can see somebody doing it for $25, machine only on a QTY of 10.
Nothing is particularly stupid or out of whack, except for the depths on the holes, and they might be needed, but
the .0025 deep and .007 wide step tells me they aren't.... and if they were there would be a corner rad in there, and
there wouldn't be a .0025 deep counter bore. I'm guessing somebody imported a DXF or something of a press in
grease fitting and made the hole dimensions the same.
Interesting way to draw the part. Must be some new fangled CAD thing.
Actually its pretty easy. For example on the counterbore use a low limit qualified length gage pin in the hole. If no radius called out, the pin should be dead sharp on the corners. It must go in the hole low limit depth. Make another gage pin thats just over high limit on the small hole. It can't go down more than high limit depth.
Thats a really BS print. I've had ones like that where someone said "Oh, make it as close as you can", and I've had ones like that where every dimension had to be on with certified and calibrated gages, 100% acceptance testing. Notes in the title block can also make make or break the job. The difference in price is orders of magnitude.
Hey Mark, you got a price of over $500 because of that stupid hole. The rest of it is pretty much a no brainer.
Yep. No way to make that hole without grinding a tool. That means you will be paying for the tool. If you were making 10,000 parts, the tooling cost would be trivial. For 10, you will pay out the nose.
There are some industry standards to b/p configuration that, when used, help ensure clarity on everyone's part. I'm not sure how you are getting quotes from your b/p, there is not enough info there.
Notice
