What would your steel supplier do to correct this problem?
Page 1 of 2 12 LastLast
Results 1 to 20 of 24
    Aug 2006
    greensboro,northcarolina
    2,604
    179
    692
    Default What would your steel supplier do to correct this problem?
    We have about $600.00 labor into a part of 440C stainless steel and have found an inclusion that makes the part unusable (medical metering pump). Cannot weld or go under size. I have asked for a replacement piece of material ( 2 by 2 1/4 by 10") at no charge and told the steel supplier about my labor costs and asked what they are willing to do. Waiting for an answer. Been doing business with this supplier for 25 + years. Picture attached.img_20210303_070909164.jpg
    Sep 2015
    Ohio
    1,673
    1115
    1734
    That's a tough one. Is that $600 actual labor dollars or $600 shop rate dollars?
    I think I'd be happy if they were willing to cover my actual labor dollars, but in reality I don't think you'll get anything other than a new pc of stock.
  3. Likes Trueturning liked this post
    Jul 2006
    Hillsboro, New Hampshire
    12,436
    2848
    8650
    It sucks, but I suspect if you get some compensation for labor it'll be a courtesy from the steel vendor, not policy.
    If you get a replacement piece from the company, either do a radiology test (Xray) on the part, or cut into waste areas and do a penetrant test (much cheaper) to look for cracks or voids.
    Jul 2007
    UNITED KINGDOM
    5,378
    3303
    2760
    If the steel order hadn't specified with full ultrasonic or radiographic inspection or certification of no inclusions, I'd expect them to supply you with another piece of the same stock at the most. Possibly not even that. Without that, the amount of labour you've put into the stock is not really their problem.
    Sorry.
    Apr 2005
    Brandon, MS
    877
    134
    201
    Replacement material and a box of doughnuts with an apology note.
    Aug 2006
    2,604
    179
    692
    $600.00 shop rate dollars. They are supplying a new piece at no cost, asked me to hang onto the part in case they want to analyze it. It's kind of what I expected, but I like the doughnut idea.
  8. Likes woodchuckNJ liked this post
  9. #7
    Jul 2008
    South Carolina
    1,009
    583
    694
    One thing to possibly consider, if your supplier is a middle man and not the steel producer. That somewhat puts the issue going back up the supply line. Not saying they won't make it good but puts them in the spot as well.
    Hodge
  10. Likes SND liked this post
  11. #8
    Sep 2015
    604
    23
    293
    Yep, a new piece of stock at no charge is going to be the best you could hope for on that one. No supplier I've ever heard of will do much beyond that. Machine at your own risk!
  12. Likes BT Fabrication liked this post
  13. #9
    Jul 2003
    Carson City, Nv. USA
    914
    728
    490
    I think they should replace your material & if they covered any outside heat treating cost, that would be good customer service.
  14. #10
    Jan 2003
    Canada
    11,569
    6347
    3724
    Material flaws are an ongoing issue and it seems to be getting worse, and worse, and worse, and material stresses!!!!!
    There's one type of parts I make in 316 that I lose about 10-15% due to material flaws(voids/cracks). Doesn't matter if its USA, India or whatever else material. It's been steady like that for the 10 years I've been making them.
    One time I got replacement was when I was sold the wrong alloy. I ate the cost of the hours that had been spent roughing it out, thankfully they weren't completely finished and delivered. I just happened to do a scrap run and when they scanned it, chips came up as not 316...
    oh and there was one time I was sold the wrong thickness of sheet, I didn't notice it was missing .010", bandsawed it all and then noticed on the first piece that went in the machine that something didn't look right.... so they replaced the sheets and I threw the blanks in the scrap bin. I was ok with that, life went on.
    I've seen other issues before when I had a day job, usually the supplier only sent a new piece and we all hoped it wasn't gonna be another bad one.
  15. #11
    Apr 2005
    Beaverdam, Virginia
    10,042
    1471
    5313
    As others have said anything above replacing the bad material would be them going above and beyond what anyone else would do. I am sure you have heard the horror stories of anodizing shops scrapping expensive parts and only being liable for the cost of raw material. Threads like this sure make me glad I make small parts where it is rare if my material cost per part exceeds $1. Mostly bar fed lathe stuff. I never have to be anxious every time I do a line inspection if I let something run too long without checking it.
  16. Likes Booze Daily, Oldwrench, Jashley73 liked this post
  17. #12
    Nov 2015
    537
    232
    Given a long good relationship I wouldn't expect them to do more than a new chunk of material, and only then if it's not a frequent thing. We can debate which direction the donuts should go. If this is one of the bigger issues you've had in that many years I'd say you're doing well.
    Former job we had a higher volume (100k/year) sort of part where the incoming steel occasionally had a cold seam. Somewhere between finish machining and the end customer they part would just up and split in half at the seam every now and then. We would complain and the suppler of the blanks basically said:
    1. We can send you a new blank in exchange for that one. Honestly though at 100k parts/year the cost of the blank isn't the issue.
    2. We are willing to guarantee this doesn't happen, but only if we 100% radiology test the parts, you give us a spec., and pay for the cost of the testing.
    3. Additional note that the mill we had making the steel was known for having this issue a bit more than others. We were buying mill runs of material, so that was a realistic thing to change. However, all other mills were more expensive (guess why), so there would be a cost increase to cover that delta.
    At the end of the day we either kept complaining but did nothing, or changed the mill, I don't remember. We did put a note in future RFQs not to use that mill.
    Point being, this falls under the cost of doing business. It's a risk you take. It can be avoided with material testing, but just eating it every now and then carries less direct costs than properly preventing it.
  18. #13
    Jan 2007
    Flushing/Flint, Michigan
    10,152
    570
    8310
    Supplier relationship, volume bought, contract wording.... and lots of other things.
    In the auto world god forbid bad stock gets into a car.
    Worse yet by miles if a safety recall. Not only unsafe but one has to give out free loaner cars as the problem is fixed.
    Money is lost and everyone works their butt off to pass the charges and costs out of my account and onto someone else.
    Buying material on price alone seems great until the day with such problems.
    Over the last xx years did this supplier save you money in raw stock? If so will this loss and frustration be a bigger dollar value.
    Bob
  19. #14
    Aug 2006
    2,604
    179
    692
    Yes, its a good suppler (distributor, not manufacturer)and I don't expect them to do anything other than replace the materiel. Don't know if the mill will do anything, they are ultimately the responsible party.
  20. #15
    May 2009
    Wyoming
    3,652
    9166
    5944
    We have used Jorgensen (EMJ) as our steel and aluminum supplier for over 40 years and rarely have any defective material issues. However, when they took over a big tubing supplier (Kilsby-Roberts IIRC) they inherited that supplier's mill sources.
    We use a lot of 1-1/4 OD DOM and got a batch with a visible seam, deep enough that it could not be "removed by machining to the nominal diameter" (the accepted standard) and the mill, after examining a specimen we returned, rejected my complaint. I got on the phone and said, "this tubing becomes the steering column of a Cup car, would you accept it being rejected by a NASCAR technical inspector? We can't use it!" and even that didn't faze them.
    So we just had EMJ exclude that mill as a source for our material and have never had a problem after that. If you have a good relationship with your supplier you can almost certainly do the same.
  21. #16
    Aug 2013
    Chicago, IL
    1,235
    885
    490
    Our heat treater cracked an expensive piece and they reimbursed us for labor but not overhead.
  22. #17
    Jul 2006
    12,436
    2848
    8650
    Quote Originally Posted by Nerdlinger View Post
    That's pretty good - usually you just get your scrap back...
  23. Likes tdmidget, Bobw liked this post
  24. #18
    Oct 2017
    1,238
    374
    423
    We had a supplier give us aluminum that didn't meet our expectations. They said it was technically in spec, but agreed it wasn't great and replaced the sheet and no longer bought from that mill in Egypt.
    We had a lot of labor into it as we were able to work around the warping of the material and cut a few sheets just to find it cracked in half when bent. The were not able to cover labor but did supply a few condolences remnants of material we often use, and they did look into whether they had any way of getting the parts we already cut heat treated but it was found not to be a temper related issue.
    We haven't had any issues getting sheets with delaminations, gouges, inclusions, etc rejected or returned with any supplier.
    We have learned that tolerances on 5052 are very, very wide and pretty meaningless. We had material 0.01" too thin and another sheet with very extreme distortion and it was all in spec. Hell, we had a batch of sheets that was 60 inches wide and 120 inches long, as it's supposed to be, except it was sheared at 89 degrees so none of our nested files fit.
  25. #19
    Feb 2007
    Aberdeen, UK
    4,498
    1633
    2079
    I expect any of our suppliers would tell us it's our fault for not UT-ing it first, and maybe replace the piece of material.
  26. #20
    Jul 2004
    Asheville NC USA
    8,893
    3762
    3066
    I'd be concerned in a situation like this that the replacement piece may be another cut off the same bar and I'd find the same problem again after investing a second $600.
