What are you making these days? Some fab shop pics from our place - Page 7
Page 7 of 7 FirstFirst ... 567
Results 121 to 132 of 132
  1. #121
    Mar 2013
    FALKLAND ISLANDS (MALVINAS)
    1,930
    2322
    1216
    Free loo roll holder with every roll!
  2. #122
    Mar 2009
    Eureka, CA
    3,907
    813
    1411
    Well..veering off the main theme of this thread a tad as I'm sheltered in place, hiding from Covid-19, and am between crossword puzzles, I though I'd share this bit of nonsense.
    My youngest son and I made this 20 years ago + for a grade school science challenge.
    The submarine was to be placed into a tank of water, submerge to the bottom then surface, all by itself..with no outside fiddling.
    When placed in the tank of water, a Alka-Seltzer tablet covering a hole soon dissolved which allowed water to enter the sub and sink it. As the sub sank, one of the brass vent tubes sticking out of the conning tower allowed water to enter a chamber which held another Alka-Seltzer tablet. This tablet held a small string that kept a lead weight tucked underneath the sub and gave it weight to allow it to sink.
    After the sub sunk and was resting on the bottom the Alka-Seltzer tablet holding the weight started dissolving. When it fully dissolved, the weight was disconnected from the sub and it now floated to the top of the tank via natural buoyancy...magic to the kiddies for sure.
    Can you still get Alka-Seltzer tablets?
    Stuart
  3. #123
    Dec 2018
    Oregon
    69
    58
    9
    That is an awesome middle school science project!
    Quote Originally Posted by atomarc View Post
    Yes:
  4. #124
    Apr 2005
    Beaverdam, Virginia
    8,143
    916
    3917
    Quote Originally Posted by johfoster View Post
    Here is that fireplace from my last post finished.
    Attachment 282011
    Attachment 282012
    I just have to say WTF to that. I suppose I don't have modern tastes. Looks like it would be real messy to remove the ashes.
  5. Likes Ox, atomarc liked this post
  6. #125
    Mar 2009
    Eureka, CA
    3,907
    813
    1411
    Not my taste either but your workmanship looks excellent.
    A question though..doesn't cement spall and explode when subject to heat such as a fire. I know it does if you hit it with a torch.
    Stuart
  7. #126
    Dec 2016
    Arizona
    234
    111
    134
    Quote Originally Posted by Dualkit View Post
    Not everyone has the same tastes thats fine. It is definitely a modern home. Not sure about the ashes removal, but they probably just sweep them up with a dust pan I figure. Keep in mind that where we are in AZ there are many more +110 degree days than -32 degree days so it won't get used for 9 months out of the year, and won't ever NEED to be a dependable source of heat.
    Stuart
    Thank-you. Yes it certainly will degrade the cement, and we made sure that the homeowner knew this is going to happen. We have discussed adding a plate steel tray for the fire to burn over to protect the concrete. No fireplace is without maintenance and repairs over time, but this will likely wear much faster than a firebrick base would. Like I said above though we are in the desert and fireplaces don't get used for most of the year.
  8. #127
    Jan 2015
    Missouri
    1,141
    218
    696
    Made this part today
  9. Likes cnctoolcat liked this post
  10. #128
    Sep 2015
    479
    23
    206
    I designed and built this fixture to run these little guys
    Attached Thumbnails Attached Thumbnails 704bae78-bf13-440a-b877-446612000ab1.jpg
  11. #129
    Aug 2002
    West Unity, Ohio
    26,105
    6373
    8535
    Quote Originally Posted by Spruewell View Post
    That looks interesting, but really can't hardly see it.
    Think Snow Eh!
    Ox
  12. #130
    Nov 2015
    386
    142
    Quote Originally Posted by RJT View Post
    Making crankshafts. Dual centers on each end so we can turn and grind each journal between centers. Then wire Edm off each end. Finished grinding after heat treat. Finished part on right side of first picture with end slug that had been removed.
    Sent from my moto z3 using Tapatalk
    I like the two centers thing. Have had some parts in the past that would have been much easier than putting an offset tool on the end. I'm curious why you start with such a large diameter piece of stock though?
  13. #131
    Aug 2005
    Toronto
    5,091
    3432
    3963
    If the sky really is falling.....I'm getting under this 115' double box girder 30ton crane currently on the floor. Biggest thing we've made.
    Ontario is closing all non essential businesses.....but about everything except your favourite nail salon is listed as essential. Construction, finance, all manufacturing, distribution, insurance, mining, it'd be a shorter list to identify what isn't essential. So we're going to crank it, open for business, practice the key behaviours and start dialing for dollars (selling)
  14. #132
    Aug 2006
    greensboro,northcarolina
    2,466
    163
    623
    That's a fixture in the 3 jaw chuck with the part shape (double D) wire edmed through it (slip fit ) and part held in with set screws. Part is held by either end to turn journal in center for this operation.
    Video show next operation with part reversed in fixture turning end journal.
    YouTube
