Winterizing Shop Warehouse
Results 1 to 12 of 12
    Oct 2019
    Massachusetts
    25
    Default Winterizing Shop Warehouse
    Looking for some tips, tricks, and solutions for winterizing shop warehouse. Relatively large space with a high ceiling cap. Best temp to Maintain? How to Protect Machinery? What to stock up on?
    Oct 2005
    16,590
    Is this where you store the junk machinery your gracing our "for sale section" with ?
    FWIW it's been discussed several times in the past, search the archives.
    Oct 2019
    Massachusetts
    25
    will do. thanks
    Sep 2012
    California, Ventura county
    1,446
    260
    609
    20 C. is standard temp or about 68 F.
    now just have to maintain standard pressure as well
    Virginia
    28,872
    7561
    8966
    Quote Originally Posted by 72bwhite View Post
    Only if you are right ON the beach, Ventura. Sea-level thing.
    More to the OP's needs.. the most important part wherever industrial goods, fine tools, close fits, corrosion-prone finishes, dis-similar metals, or electronics live is avoiding "condensing humidity" more than any specific temp swing alone. Winters are usually dry, but not everywhere. Some heating choices add moisture.
    See also "dew point", "degree days", and the annual history of the weather, US Gov. services, your specific area.
    What to DO about it, covered arredy. And "right here on PM". As Digger said.
    Mar 2011
    MASS
    966
    419
    304
    Quote Originally Posted by theothertom View Post
    youll want to maintain 55 in the shop at least for storage here in new england
    Oct 2019
    Massachusetts
    25
    Thanks for the replies. I will take them all into careful consideration. Thanks Again.
    May 2019
    ALGERIA
    16
    In Red Deer Alberta Canada its -14 feels like -20c
    My 1400 sqft shop I keep it at 13-15c all winter
    I have lathes, huge box of tools etc but the trick I believe is air movement. Iíll back my truck in over night with a ton of snow on it, I try to sweep most of the water out but I leave my ceiling fans run all winter.
    Iíve never had a rust problem.
    I heat it with a mid efficiency furnace that blows across the garage.
  9. Likes Ox liked this post
  10. #9
    Oct 2005
    16,590
    Quote Originally Posted by overkill19 View Post
    ...and yet, your location says "Algeria".....
    IIRC Alberta is "dry" in winter.
    very dry....
  11. #10
    Sep 2002
    People's Republic
    3,745
    330
    2397
    the most important step is to keep it above freezing at all times.
    Generally not that expensive to do.
    Next step is mid low 40's, keeps it so tools don't feel cold to the touch and it is pretty easy to crank it up into working temps.
    As mentioned it is about the temperature swings, so keeping it at 40, Dec thru March, you are probably only seeing 10-15 degree swings, keeps condensation down.
  12. #11
    May 2019
    ALGERIA
    16
    very dry....
    If you can change it go for it... Iíve tried a million times.... it keeps defaulting to Algeria, Provence says Alberta thou thx.
    Yes winters can be dry here but 1 foot of snow on a Dodge mega cab, wifeís Tiguan plus all the frozen slush stuck to undercarriage.... itís far from dry in my shop daily!
  13. #12
    May 2010
    NY, USA
    66
    11
    I second the moving air - I use the pivoting wall mount fans. When working a lot in front of one in the winter, I will turn it off until I am done for the day.
