Stand in front of a lathe for ten years and you can turn a tenth, doesn't matter what the compound angle is. Not before.
Truthfully, the monarchs divisions are wide enough, that with care, IE, same approach cuts every time, you can come within a couple thou on your rough, and tap it in to a few tenths every time. Beats screwing up your Z dimension to try with the compound
