Removing the Collet Closure
kory
Sep 1, 2003
Billings, MT
I'm trying to remove the collet closer from an HLV-H and having some problems. I'm new to HLV's in general and I don't know the last time the link pin was pulled out, but I just can't seem to remove the pin. Does it pull straight up? No twisting? I sprayed some WD-40 in case it had seized, but that didn't help. Any suggestions would be great.
Thanks,
Kory
Thanks Mike! Tapping the bottom with a hammer did the trick. I've very nervous about using a hammer on a machine like this.
The manual states to lubricate it with light oil. What do you use? I have some of the recommended spindle oil. Will that do?
Thanks,
Kory
