Hi there.
I have a baikal 12ga single barrel that I plan to put sights on.Front sight will be no problem.Rear sight I want to solder on the barrel above the chamber.Problem is that the locking lug is silver soldered to the barrel so Im a little fraid to solder /heat that end.Chamber walls are about 1/8" thick so drilling is not an option.
Any suggestions? Will be making the gohst ring type sight my self so I can compensate for any method.
Acraglass maybe?
Thanks in advance.
Össi
Iceland
Acraglass maybe?
Thanks in advance.
Össi
Iceland
