Gosh, wish you had made a post earlier, I would have steered you to Dave Kiff at Pacific Tool & Grinding (PTG)
I have a little over 90 reamers in the chest (counted them two months ago, have a few more delivered since). I have all makes, including some old names: Redford, Hartford, Hendrickson, some made by the old master Keith Francis before JGS days, Clymer, JGS, and a lot of PTG. PTG makes the best, they cut on all flutes, and removable pilot reamers run about $150, doesn't make any difference what special grinds you want, tight neck, wildcats, all the same.
Clymer has gone by the wayside, no longer owned by true gun folks. I can tell some horror stories about reamer makers and gun plumbers, but best leave these tales off a public forum.
Give me a shout if you need help on specials, tight necks, tight bases, throat angles, leads, etc, I have made about all the mistakes.
Check those bore sizes on the barrels, and best if you buy sets of bushings so you can fit a tight bushing. Important in accuracy rifles, and also important in preventing chatter: Some reamer profiles are prone to chatter if the pilot is loose in the bore by a thou or so.
