J_R_Thiele
- Jan 22, 2003
- Columbia Missouri
I purchased a Utica TS-100 torque screwdriver off of E-Bay. It should adjust up to100 in-lb. It has a recent calibration sticker, but the torque not even close to what it should be when tested with a beam type wrench of similar range. I believe it was calibrated for some special purpose and the adjustable feature not used.
I would like to know how to adjust it. I can use the beam wrench to get values close enough for my purposes. I have tried to increase the torque with the allen head set screw in the end. As it is turned in the torque does increase- but at about15 in-lb the screw is in so far it is running out of thread. I have to wonder if the original set screw was replaced with a shorter one.
Does anyone have any instructions or suggestions?
