Paul_Gauthier
- Jul 27, 2003
Picked up this sporterized 03-A3 barreled action with cheap scope and Lyman reciever sight. The bore is in excellent condition as I would expect from a replacement barrel. Here are pics.
Note the bolt pics, some moron reduced the bolt dia. around the rear lug with a hand grinder. Can't think of a reason for that.
Note also the pos scope mount (B-Square) that replaces the bolt release. One of their famous "no gunsmithing mounts".
Will aquire a new complete bent bolt from Gun Parts Inc. and all parts for bolt release, a used stock. Will clean, grit blast, check headspace, adjust if needed.
reblue and hopefully will have a good shooter. Will have about $225.00 into it when finished.
Paul G
Paul G
