dwilliams1128
- Jul 27, 2004
Hello
I like verticle metal mills better than horizontal because horizontal are too much like a lathe. But isn't ether type of mill able to be duplicted in work by the lathe?
Someone said earlier that in order to make an engine I'd need a milling machine as well as a lathe or at least it would make the task easier. I can understand that you can turn out a cylinder and a piston on a lathe. But a connecting rod and borring out a crank case sounds like a job for a mill. Doesn't it?
I got the book about How to Run a Lathe by Lindsay and it starts out into the history of the lathe. Like saying that the early lathe was a wooden work piece supported with 2 wooden poles and a wood lath (like a sappling wrapped around the workpiece made it go around). The word lath for sappling was how the turning machine got its name lathe.
I've seen in real life lathes as big as nearly 20' long and I've heard of them being even bigger (like 50 or 70 almost 80 feet long for ship yards).
Thank you everyone.
David.
Thank you everyone.
David.
