Yes, doc, I'd like to hear more on that Hornet perversion. I've got a couple Krags laying around too.
Habu & Jess
bushings i have done have been on single shots....but have seen couple krag hornets ..they were done in the thirtys when NRA sold krags for $1.50 or so , & money was scarce as were bolt actions ...by 1955 ,we were flooded w/ military surplus ......conversions used a bush to reduce opening in end of bolt to surround the hornetrim ,like a flattened doughnut ...joint was clearly visible ,so probably a lite press fit...side loading slapped off ,eliminated & a plate fitted ,so cud be inletted in stock ....SS loading platform pinned in ...it wud have been possible to spot anneal in the center ,drill & thrd to hold the bush , as well ..we welded a lot w/ wet torch,wet rags, even in h2o , up to the area welded, so anneal cud be done w/out affecting lug ,....( maybe a little drawn temper wud help the deep case)...extension was silver soldered on extractor .....i was dubious of strenght on first SS xtractor done this way , but none failed....simply cut off old one & s/soldered in a plate on a ledge cut in shank ....fit the plate into end of barrel & cut the rim hold w/ the reamer.....even fitted up some rimless w/ wallowed out action pin hole & spring loaded from side of action or front for overididng the rim as block closed ....
....by the time i started right after war, conversions to krag hornet were already passe
FWIW ...i menioned earlier that i saw a win.lowall rebarrellerd to 218 mashburn bee abt this time ,done by mashburn arms , st.louis mo. . so apparantly he thot a lowall wud hold an improved bee,contrary to most arms pundits of the time.....
best wishes
docn8as
