Grits
- Dec 14, 2004
- Little Rock, Arkansaw
With accuracy as my goal, how advantageous is it to use reamers with a live pilot instead of reamers with a solid pilot? I understand why a live pilot that is bushed to fit the bore exactly should be the most accurate; however, from a practical standpoint, how much difference does it make?
Here are a couple of examples. I plan on building a 7x57 on a M70 action with a #3 taper barrel. I will use a Hart or Shilen Select Match grade blank. I want the rifle accurate but in reality, it will be a two hundred yard deer rifle. A few hundredths in the group does not matter but a half inch does.
The second will be a 6.5 STW bean field rifle. I will use either a 70 or 700 action with a #5 or #6 taper. I will use the same quality of barrel mentioned above. I want this rifle to be as accurate as practically possible.
How close would you match the rotating bushing? Is it worth buying the nine bushing set for one caliber for $90 to get it within a tenth or two of the bore size?
Even though this is my hobby, I strive to build my projects as accurate as possible. To me, time is not a factor, perfection is. that is why I do it.
To make all this simple, do piloted reamers make a noticeable difference in cutting a rifle chamber in a sporter (non benchrest rifle)?
Thank you for your advise.
Grits
Grits
