JW Machine
- Feb 11, 2007
- Minnesota
I am not new to machining, but now have some gunsmithing work for the first time and would appreciate some advice.
I need to thread the ends of some new barrels to fit them into receivers. I am planning to indicate off the bore for this, chucking on the cylindrical portion of the barrel just ahead of the receiver, as the rest of its length is tapered.
My question is this: Is the barrel OD parallel enough to the bore for this to be accurate? I know they are not necessarily coaxial, but I can adjust for this with my chuck. However, if they are not parallel, I think I will need to find a new way to indicate or hold the barrel to make sure the threads are both parallel and coaxial with the bore.
As I said, I am new to gunsmithing. Is this a valid concern, or am I attempting to achieve an unnecessary level of accuracy?
