We just got rid of a Nordic 25 engine lathe here at the power plant. The reason we got rid of it was that an electromagnetic clutch in the headstock failed. Even when Southbend was reasonably healthy, they did not support us when we'd call them for parts for this Nordic lathe. We knew this clutch was giving out, and Southbend, even a few years back was no help. They explained that they had taken on the "Nordic" line in the 1960's-1970's and then ditched it. What we found out was the Nordic lathes were made by a French firm caled "Muller & Pessant". Muller & Pessant ditched the Nordic line, selling the rights to some Belgian firm, who did even less with it. We once tried to contact the Belgian firm directly for parts and got nowheres. The clutch was made by Warner of France, and it proved impossible to get another clutch from them- if it was not obsoleted. LeBlond, Ltd found what they thought was the right clutch in stock in the USA. Fortunately, they sent us dimensions of the clutch they found and a cross section of the headstock of the Nordic lathe it was for. Surprise- Nordic had a few versions of headstock internals for the same size/line of lathe. In short, a Nordic lathe is a mongrel that no one seems to support. When the clutch failed in the Nordic 25 lathe here at the power plant, LeBlond Ltd DID try pretty hard to help us find a replacement. They had very little information to go on because Southbend had never really supported the Nordic lathes for some years previous. LeBlond, Ltd called around the US to various rebuilders but could not come up with the right replacement clutch. We got prices to convert the Nordic 25 to get rid of the electromagnetic clutches and put in an AC inverter drive. All the electrics, including the motor mounting would have had to have been replaced. It was not worth it. We took that Nordic out of the plant and it is in the boneyard rusting. Ways were like brand new, cross slide & compound rescraped a few years earlier. We figured it was a light duty lathe, parts were impossible to come by, so out it went. It will likely go for junk.
We are putting in a 24" x 96" heavy duty LeBlond engine lathe. No one would even take the Nordic in trade. Baby the one you've got, because if something lets go, you could be all done.
Joe Michaels
