ChipBed
- Jan 7, 2005
- Rochester, NY
I have a "new-to-me" 1947 vintage 13" SBL. I haven't had a chance to really go over it, but the spindle sounds OK when I run it. My question is, the previous owner lubricated all the cups with 10W-30 motor oil. Of course when I pointed out to him that the lube plate says "Don't us automotive oil", he says "That's only because the lathe companies want you to buy oil from them." - Errrrggggghhhhh !!!!
He used the lathe only intermittantly (couple of hours a month or so ??) while he's had it, which is probably 12 years or so.
Has running it with motor oil possibly contributed to shortening the life of the spindle bearings? If I change to a good grade spindle oil (i.e. Mobil Velocite or equivilent) from now on be OK or do I need to flush & fill and, if so, how would you go about flushing it ?
Thanks a million for any help you can provide,
-Bob
-Bob
