BadDog
- Mar 27, 2006
- Phoenix, AZ
Tonight I set up a sort of home made tool post grinder using a die grinder pencil wand and 1/2 AO “drum”. The 3 jaw Buck (Logan) that came with my lathe has a set of hard jaws that are bell mouthed and TIR *at the chuck* was 0.003+ if your lucky and could get a bite over half way back. Chucked a 3/4” hex nut at the very back and ground away till I got a good pattern along all 3 jaws. First pass told the story as one jaw was not even touched as the other 2 (one in particular) were taking most of the grinding. Results are less than stellar, but at least it will make a somewhat decent chuck for small non-precision stuff without having to use the 2 piece jaws all the time (I don’t like them for small stuff).
Anyway, I covered the forward part of the ways and as much of the cross as was convenient without getting in the way. Still, there was quite a bit of powdery abrasive residue all over and inside the chuck as well as on the saddle and elsewhere. I carefully wiped everything down with dry paper towels, making sure not to push gunk into the wrong places. Then wiped down with an oily rag to hopefully trap any stray particles. But I did not disassemble the chuck or carriage for thorough cleaning. Sometimes I go to greater extents, sometimes I’m less diligent. But I wonder if I shouldn’t go further to protect my newly refinished lathe.
For jobs like this and many others you can imagine, there is no option BUT to grind on the lathe, as much as I prefer to avoid it. How far DO you go in cleaning and what tips do you have for doing a good/adequate job?
Searching didn’t turn up anything, so I figured it might be useful to discuss...
