I was recently looking at the schematic in the manual of my VFD, and I had an idea! How about hooking up an external heavy duty bridge rectifier and capacitor to VFDs that are supposed to take 3 phase power only??? The only reason to de-rate a VFD that's ONLY supposed to take 3 phase is because the diodes and caps aren't big enough to compensate for the lack of a phase in the supply. The DC bus voltage, and everything after that is the same. The VFD even has the terminals setup in such a way that you DO NOT have to open the case to do this, at least on my hitachi. I'm pretty sure that other VFDs are the same. There are terminals labeled "+1", "-" and "+" where the DC bus and diodes are connected together by a jumper across the "+" (DC bus), and "+1" (positive diode output) terminals. You'd simply connect a big bridge rectifier, and a cap appropriately sized for the current to the "+" and "-" terminals, and remove the jumper! I know the control circuitry on the Hitachi is supplied through the DC bus because when the power is removed, the display stays on until the cap drains. If you had a VFD where the control circuitry is fed through the AC inputs, or needs the AC inputs powered because it needs to detect voltage there, just hook up the AC to the proper input terminals. You don't even need to use fat wire (to the original ac inputs), because they're only bearing the load of the control circuitry after that. Has anybody else thought of this?? It sure would save $$$ over buying a VFD twice as big as you need because the stinking diodes and caps are too small! Why wouldn't most companies offer VFDs with single phase capability over 3hp that DON'T require de-rating?!?! I swear they must do this on purpose to screw people! It's just INSANE what they want for big VFDs, and double the size means 1.75x the price. So, if you need a 10hp VFD, you're looking at BIG$$$ for a 20 hp unit!!! Screw that, this seems to be a MUCH better way to go! This should work, any reason it wouldn't???
