rimcanyon
- Sep 28, 2002
- Salinas, CA USA
I'm not completely done bringing my 57 WiaD lathe back to life, but progress has been encouraging, and while the facts are still fresh in my mind I wanted to give at least a partial recount since it may be of use to others who need to debug their DC drive.
I purchased the '57 2-3 years ago, and it showed signs of a complete rebuild and mechanically it was in fine shape (missing a few components that walked while it was sitting). The WiaD on the other hand was a mess. The wiring had disintegrated, many components had shorted and were bad, and it clearly had not run in a long time.
The lathe came from Hughes aircraft, so presumably it had regular maintenance until it developed electrical problems. It appears not to have been running for at least 10 years.
I decided to add ELSR and VSR and to completely rewire the WiaD. I also obtained a set of 220V transformers, and converted the lathe from 440V to 220V. I was fortunate enough to locate the correct wiring diagram and schematic for a WiaD lathe with ELSR & VSR, so the task was a matter of noting the differences between the existing wiring and the new wiring, and of obtaining a few components required by the conversion that I did not have. I purchased a 120V coil for the main contactor, since the control circuitry used for ELSR does not use line current, and a 120V relay for switching the speed potentiometers, used by the VSR. Otherwise I had most of the components needed, cannibalized from various parts lathes.
Adding ELSR meant running a conduit from the on/off switch box to the tailstock area, through the coolant pump cavity, then running wires from ELSR and VSR (which is mounted on the plate at the tail end of the bed), to the WiAD, to the main contactor, to the DC panel. All those wires cross at the On/Off switch box.
Rewiring the WiaD gave me a chance to test all of the components on the board that I would normally not be able to isolate easily, so I found some bad resistors, and replaced the High Speed pot and the compensation pot. The grid transformers were in bad shape so I replaced them with a pair that came from another machine.
Both anode transformers are dual voltage so they were wired for 220V.
When that work was done, the machine sat for almost a year, until two weeks ago when I finally got enough courage to turn on the power and start debugging. Fortunately, nothing spectacular happened when the power did go on, but I ran into my first debugging problem.
The Field Loss relay would not stay engaged when the on button was pressed.
I measured the field (F1-F2), and there was none. That was symptomatic of a bad 6SF5 tube. So I replaced the tube. I also replaced both 3C23's and the EL1C with new tubes.
Now I actually had DC field voltage: 58V to be precise. Since I had just rewired the entire WiaD, I followed every path shown in the schematic for the field, found one loose connection not related, and everything else checked out. Then it occurred to me, perhaps the grid transformer that I had just replaced needed to be in-phase with the anode transformer. OK, I'm no EE, so who you gonna call? Yep, an email to Peter elicited a confirmation on that point, along with the information that the F2 and E1 center tap connections needed to be on the yellow and orange wires from the filament transformer, and the DD and CC connections needed to be on the red and green wires respectively. Turns out that the Monarch circuit diagram had an error. OK, so I fixed that and reversed the polarity of the grid transformer for the field.
Now my field voltage is respectable: 98VDC. I actually got a 110VDC field at one point (I had the F2 and E1 connections reversed and the grid transformer reversed from its current connection), but now it is wired according to schematic. I think I need a scope to verify that the relative phase of the two transformers is actually correct, unless there is another way...(??)
Next problem: the field voltage does not vary as the controls are adjusted.
I haven't solved this one yet. This is what I know: after disconnecting both speed pots and the FA relay coil and the F -25- R path, there is only one device connecting terminal 13 to terminal 15: the high speed pot. I have verified that the resistance varies from 0 to 27K ohms as the high speed pot is adjusted. I measured that right at the connector base for the 6SF5. However, the 6SF5 tube is not doing its job. Field voltage remains constant at 95V, despite the setting of the high speed pot.
Tonight I will try another 6SF5 tube. I'll also record the voltage drop across the 51K resistor connected to the 6SF5 tube. And I will check the resistance between F2 and the grid transformer secondary, which should be infinite.
