Nick,
Treat this as a red pencil markup of your drawing, nothing more, no
bad feelings.
the 5mm dia. stock is just that, the stock dia. not the finished dia.
you want, place that on the part.
All these words you sent me do not get conveyed on the drawing
(were they are needed) in fact less time is spent in properly dimensioning
a drawing then typing the paragraph explaining what is wanted.
The drawing IS the contract, it should convey all the info.
"These shafts are to fit inside a 5mm bearing. Bearing should slide on and be able to be removed easily"
what kind of bearing ? the tolerance of the bearing is important for the next
question... fit, loose,slip, or press.You said slide on, assume slip not loose.
I'm not harping on you because I want to, it's just when you ask for a quote,
give these guys a fully toleranced drawing, or they will pick and hunt you with
all these questions and more.
.003 hole location on drilled holes is tight ,.012r is our standard and it means
this:
Draw on cad, the cross hairs where you want the hole, in the
ether world of perfection (the cad screen) now draw a circle around
that cross hair with a radius of .012". The actual hole centerline
is allowed to deviate anywhere in that area.
other people have other tolerances, and ways of expressing it.
So if I can take a little license here, what you really want is someone
to take some 5mm (don't mix units metric/english BTW) P&G (polished
and ground) stock (something hard). Cut this off, and drill some cross
holes in it.
As I tell people, the devil is in the details.
