Sierevello
Banned
- Mar 21, 2005
Can anyone comment on whether a thread relief groove hurts accuracy on a rifle if you use one cutting the threads on a new barrel blank?
Thanks, Steve
Thanks, Steve
No groove needed... invert the threading tool, set compound to the left (29.5º or 30º) instead of to the right, run lathe CW instead of CCW, set carriage stop or use a dial indicator to insure the came starting point of threads and thread away.
With the carriage moving away from the headstock, you don't have to be concerned about reaching the end of the thread, it is no longer cutting anything.
Only problem is, if you have a threaded spindle on the lathe, you might unscrew your chuck.
"You can always tell other shooters that you did it that way after a lot of testing proved that it was better."
My guess is if there was a lot of testing done, it would prove that it is better or at least that there is no difference. Gary P. Hansen
Ben because the threads spiral down the barrel they do not set up the same type stress point as a groove that goes all the way around the barrel. However, with that said most likely the extra strength provided from a U groove over a V groove will never be needed. Gary P. Hansen
Notice
