stannp368
- Jan 24, 2003
- Philadelphia, PA USA
I came across an old Sharps pistol w/ all matching nos. but w/ a broken lever spring. This spring holds the lever in place which in turn actuates the dropping block. I was determined to make this spring & I took a pc of ohgs approx 3/16 x 1/4 x 1.1/2 & roughed out what I could. The finished spring looked like a miniature teaspoon. I soft soldered the bottom to a pc of crs & proceded to mill the flat spring to the required thickness of .030 x 1.1/4. From there it was easy as I melted the solder & removed the spring. Finishing up w/ appropriate needle files & riflers, the finished item was a honey. I then heat blued it & attached it to the underside w/ the orig screw which was on the gun. Have any of you gun people ever encountered a similar situation w/ a broken flat spring on an antique gun?
