CatMan
- Apr 12, 2005
- Brandon, MS
All:
I've got a large disc here that has a raised edge on the outer lip creating an inside diameter. The size of this inside diameter is 435.8mm +/- 0.04mm. I need to measure this inside diameter. The kicker is the lip is only 4mm tall, so there's not a lot of material there to form an edge.
I'm currently using a set of 24" vernier calipers, but I'd like something a little less subjective. I'd prefer something that's easy to use on the line. And simple.
