Walter A
- Jul 7, 2007
- Hampton, Virginia
Would need a price/delivery on the below:
7pc P/N will be SU90484536 rev. 0 - Adapter
Material is A36 or any mild steel (it's not a weld part so if you want to use free machining steel that's ok)
All machined finishes are 125 - Dimensional tolerance are +/- 0.2mm
Round part 110mm dia x 40mm long
C'bore one side 70mm dia x 20mm deep
Drill & Tap opposite side 2" NPT
4 holes face (C'Bored side) M8 x 18mm thread depth equal spaced on 90mm BC.
Should fit in flat rate USPS box. Would need 2 weeks ARO
Walter A.
Walter A.
