I'm more of an operator gone owner. My metrology background isn't the best, and I'm quoting a job. It as the title states is a bore diameter of 3.816" +/- .001 . The material is some type of casted material and appears to look like a section of tubing with a 9" o.d. and a 6-9/16" i.d. that is 4-1/2" long. It is counter bored to my dimension. I see no run out tolerance just the + or - .001 and my best guess is they press this over a bearing, because they are calling it a return roller.
I would plan to chuck it on a lathe. I'm not sure if I can use pie jaws yet to minimize distortion or if I will rough at a higher chuck pressure than finish at another pressure.
My question is how would you guys check this. At the place I used to work at they'd use or buy a pistol grip type 3 leged digital bore mic. I'm guessing that set up would be in the $2,000+ range. I'm not sure on the amount of future work and this customer is very touchy on asking too many questions. They are pretty loyal to keep their jobs at the same shops until they screw up. They have me quoting qty's of 10, 30, 60, 120, and 240. So my thought is they will order 10 or 30 occasionally. This customer would be casting the parts and giving to me to machine, then selling to their customer. I'm sure they'd throw me under the bus in half a heart beat if something wasn't well within tolerance. So I'm going to inspect and document every part, and give them a copy report of dimensions and save the original for myself. I'm just about positive they have no way to inspect the part and could care less. If I say it is a certain size, They will believe it until told differently, then they will make me prove what I did.
I think my machine with some effort could hold the dimensions, but I need a good way of checking the part, that will hold water if I need to defend the measurement here. I can't justify more than $500+ up front. Even writing that makes me nervous.
Bottom line, I need a good means of checking this part that any end customers inspection dept. would respect my method of machining/inspection. I'd like a bit of efficiency, and I don't typically run into parts that I need to use my bore gage(I'm trying to say I'm not comfortable trusting/using this type of gaging yet).
A big thanks in advance,
Rosie
Rosie
