I never got properly set up for measuring tight tolerance bores yet. Generally got by with telescopic gages, pin/plug gages (or making my own) and sometimes testing with the mating bearing when provided.
Now I have some crazier stuff coming up with +/-.0001 on bores(it gets crazier)
Just wondering whats out there. Lasers seem no good at doing ID's if its a blind hole.
Are Dial bore gages still where its at? I saw sunnen has a few very special bore gauging systems with incredible accuracy but they cost a fair bit and are really meant to do high quantity parts that you can take to the measuring system which stays on the table, you can't hold that set up in a lathe to measure your part.
Range I need is usually from just under .500 " to about 2" but if it goes a little bigger it doesn't hurt.
Current budget ideally under 1K but could go to 2K if its really worth it and can't be questioned as to the readings it gives me.
If it has to be a dial bore gauge(or maybe digital bore gauge by now?) who currently makes the best ones? Mitutoyo or what else should I look at?
