J_R_Thiele
- Jan 22, 2003
- Columbia Missouri
Need to touch up 60" camelback straightedge with 36" references. Best way???
I have a 60 in B&S camelback I got off of ebay- and want to true it up for use. I have a 36 X 24 in granite surface plate- and a 36 in B&S granite straightedge (neither calibrated).
I have tried spotting with both- and have not been satisfied yet with either. I am open to suggestions. I have found it physically easier to use the granite straightedge.
I am sure Connelly adresses this someplace- but I have not found it.
SURFACE PLATE
I know it is best to not have any overhang off the surface plate when spotting- but I cannot avoid this. I have tried going diagonally across the plate- but I am not strong enough to hold it extended and have the cntrol needed. I can get consistent markings when the camelback is centered on the plate with equal "hang-off". When I have all the "hang-off" to one side the strightedge marks up at the edge of the surface plate where the weight is concentrated. This is with the medium (Canode) on the plate.
Possible solutions to when I have the overhang
1 Add weight to the end on the plate to provide better balance. If I try this I need to come up with a way to attach it so it does not distort the casting- and there is no risk of something falling off onto the plate. Another possibility would be to use a weight and pulley or spring to help lift the overhanging end.
2 Use a thinner layer of marking medium and manually push down on the end on the plate. If the layer of medium is very thin it should mark up more consistently regardless of the pressure
GRANITE STRAIGHTEDGE
The granite straightedge is the same width as the camelback- and has no provisions for handles. I have used wood clamps as handles, and to add stability when putting on marking medium. It seems unlikley I distort the granite- but to keep from slipping the clamps are very tight...
I have actually found it easier to lift and manipulate the granite straightedge than the camelback.
I have the camelback inverted and held in a B&B Workmate. The back of the camelback rests on the rails- which are 24 inches apart. (To be at the airy points it should be 33 inches apart.) I have it clamped at only one point in the center to try and reduce any stress or twist.
Though the granite straightedge is easier to manipulate, it is harder to get consistent markings with. I suspect part of this is related to the difficulty of getting an even coating over its length.
In using the granite straightedge I have the camelback upside down- so there is no overhang. This also leave the camelback in the position for scraping- but not well enough supported to actually scape unless addition support were added.
Possible solutions.
1 Add second Workmate and relocate clamping points for scraping.
Add second Workmate and use one for each airey point.
Both depend on my other two model workmates matching...
2 Abandon the Workmate and build a dedicated frame to hold it on the airy points, with one clamp to hold vertical without imparting twist
Comments or suggestions on any of the above?
SURFACE PLATE
Possible solutions.
