9 x 36 BP
Ok, this is the smallest size and yes there is a bit to look out for.
1) round ram - the very oldest machines have a round ram rather than the cast iron dovetailed configuration used later. They are harder to tram and the ones I have encountered lack the nuckle joint behind the head.
2) M heads, some of the small machines were equiped with a smaller (M series, rather than J series head). M heads use morse taper collets and wont hold mills larger than about 1/2 inch.
3) BP mills are very common machines. Its not uncommon to find one cobbled together from several mills. Putting a good, new head on an old knee is a nice way to upgrade from from a J1 to J2 series head. Serial number lists can be found on line, and armed with that information you can spot significant age differences.
4) J1 heads have a step pulley- no problem if you use a VFD and do light work. J2 heads have a variable speed pulley system, so torque increases as speed drops and vise versa. You dont get that with a VFD.
5) Second hand DRO's, power feeds and one shot oilers usualy dont comand much of a premiumu on used machines, but are very pricy to add later. Hold out for a machine that has at least one power feed. A machine with a 1 shot oiler is more likely to have been properly lubricated, and a DRO is just very nice.
6) try to confirm that the borring feed system in the head works. Getting a good surface finish with a boring head without power feeds is a chalenge.
7) Open the door on the side of the column. Some machines are equiped with collant pumps, some are not. Its also not uncommon to find some forgotten treasures in their.
8) Avoid machines with holes drilled and tapped in the tables. This was probably done for a production fixture and the machine is likely to have heavily worn areas.
9) Pay for a good knee, some are worn, dished and loose, others are tight. Look closely at the ware patterns, and buy the tightest knee you can find and afford. Its a lot easier to rebuild the head than refurbish a knee.
10) Occasionaly you find a machine with a riser block to elevate the head 3 to 9 inches. It fits in the swivel joint between the column and head pivot joint. The riser allows more room between the head and table for larger parts. This can be very nice if you do a lot of work in a vise or are tall and just like the table to be a little higher. To much riser and you cant get the quill all the way down to the table. This can be a problem for short parts clamped driectly to the table.
11) Series1 and Series 2 BP, some changes to knee size were made and the hardness of the knee may be different. A little background work on the BP forum is warrented. I am not sure how the changes affected small table machines. You might find a cobbled together machine with the best of all worlds. If you do, buy a few lottery tickets.
