carla @ tactical link
- Dec 22, 2000
- mt. hamilton, ca, us
Hello, all,
This is the continuing story of my EE drive, as of today.
As was mentioned earlier, Angelo, the electrical engineer, found that I had the taps on the transformers in the wrong position, so the filament voltage was slightly out of spec. He reset the taps, and got the voltage set within the 2.5V +- 5pct. tolerance. We left the machine at that point, as Angelo said he'd have to make up a 'high voltage probe' system for his oscilloscope, to set the phasing of the tubes.
The out-of-tolerance voltage seemed a plausible cause for the failure of one of the tubes.
Yesterday, I installed the three new tubes.
Today, Angelo checked out the phasing of the C16J tubes, and, as chance would have it, I had hooked them up 'right way round', so to speak. The phasing checked out OK.
After letting the new tubes 'season' with power on their filaments for an hour, without drawing power from them by running the spindle motor (I'd been told that they needed time to do an initial vapourisation of the mercury in the tubes before they were capable of actual use), we started the machine.
The spindle motor ran smoothly, and seemed to brake alright when the switch was thrown off.
However, now the machine has a new problem.
The motor speed follows the speed control knob only up to less than half of the speed control travel. It runs smoothly and quietly up to 950 rpm, as indicated on the tach, but won't continue to increase speed past that point. The motor continues to run smoothly at 950 spindle rpm, regardless of control pot knob setting past that point, roughly a third of the control knob's range of rotation.
Previously, up until the fallure of the one C16J, the spindle speed would run up to 3500, approx. , at the max speed control setting, and seemed to follow the control knob setting normally up through its range, altho the motor would seem to 'hunt' a bit at around 3000 spindle speed.
Aside from going over large numbers of wiring terminal screws with a screw driver, to verify that none were loose, and replacing the tubes, nothing has been done to the machine's electricals.
Is this new problem, the failure to run past 950 rpm spindle speed, a known problem, with a known diagnosis/repair?
I did notice that the new C3J tube looked visually different in operation, compared to the old existing one. The old one showed a strong light blue glow, whereas the new one seemed to glow much more weakly, with what appeared to be 'red flickers' in its glow.
Could a new but defective C3J tube cause such a problem?
I haven't yet tried running the machine with the module removed, or substituting the old C3J.
Is there anything I should look for, such as some of the diode parts in the module having failed, maybe just from age?
cheers
Carla
cheers
Carla
