Hey Guys,
I'm a long time lurker of the forums. I always enjoy reading about everybody's projects. I'm long winded so to skip the back story just go down to the frown face.
On Friday I went to a gun show looking for a gopher gun for my dad. I ended up bringing home a western field 410 made by mossberg from the 30's.
Now while wandering the show I found a gun that tugged at my heart strings a 30-40 krag. I first hunted with a Krag and took my first 7 deer with it. I loved that gun. Unfortunately after my grandfather passed away my grandmother gave it to my uncle who also dragged it around when he was a kid. I ended up getting a K98 Mauser which was almost my first gun but I chose the krag instead because it was neater looking. Anyways I digress. The krag was the cheapest I've ever seen locally. I've seen some go for less on gunbroker but by the time you add shipping and fees there up to around 3-4 hundred.
This gun was sporterized and looked a lot like my old one. It had nice original stock that was cut down it had a neat old leather sling which i've found out is a 1903 springfield one. The bluing was mostly there. The gun kind of looked like crap because the seller never even cleaned it. I looked down the barrel and it was filled with junk which had me concerned. A neighboring vendor had a bore snake and after a few swipes it cleaned up pretty well. The only other two things I saw were it was missing the cutoff switch and it had one flat and one dovetail milled into the barrel right before the receiver. But i thought it would make for a good shooter.
We agreed on $190 and I took it home with me thinking I got a great deal. Once home i started cleaning it. I looked up how to take the bolt out so I could do a real good job. I spent a hour on the bore and it looks pretty nice. No pitting and the rifling is nice. A unfired round seats in the muzzle like it should and doesn't go up to the brass.
While cleaning the bolt I noticed a crack going out in both directions from the locking lug. It must have had a hot hand load fired from it at some point. My good deal went to a bad one with that find. It almost looks like somebody tried to weld it. As some material is missing from filing or grinding. Now i see the bolt also seats by the guide rib. Which acts as a safety lug along with the bolt handle. The guide rib did not seat from the armory. This is usually caused from stretching of the bolt or somebody lapping the main lug down so the safety lug will contact. This was thought to add strength back in the day by giving you two lugs. But if your main lug fails it can cause the receiver to crack if you keep shooting it like that.
Can I save the bolt? I'd hate to throw the original one out since it's been in the gun since 1898. The bolt was case hardened from the factory. I was thinking about grinding the crack down and slowly filling it with weld. Then filing the weld down. I was hoping that would keep most of the original case hardening intact on the rest of the bolt. The softer weld would be protected by the harder steel in front and behind it. I also was thinking about building up the locking lug face on the bolt as well.
Is this idea even remotely sane or should I bag the old bolt and find a new one?
Now the other thing I'd like to do is fix the bubba on the barrel. I've seen guys plug weld scope holes but never something as large as the flats machined on this one. Does anybody have any ideas? I have access to a lathe at work but I'm not experienced with using one at all. Worst case fix would be to find a original hand guard that covers the area and forget about it.
Thanks
WBCo
Thanks
WBCo
