john.k
- Dec 21, 2012
- Brisbane Qld Australia
I m working on a project,which most of you wont approve of ,that requires an insert to be soldered into the chamber of a barrel made of sae 1350.The steel is quenched in oil and tempered at 650degC.I made the insert with the required clearance,but when I went to buy some 45% silver solder,the type that melts under 650C is no longer available,as cadmium is banned ,says the salesman.The MP is now well over 700C,which will soften the barrel undesirably,in my opinion.Is there any source of 45% silver solder with cadmium still available.Regards John.
