hepburnman
- Feb 20, 2013
- NJ
Hi- I am about to knurl a 1.490" diameter piece of 6061. This will be my first time (lucky me!). From what I have read 1.490" is a good diameter to get a good diamond knurling pattern using a 25 TPI 30 degree spiral wheels. My knurling tool is the Aloris AXA-10 plunge-type knurler. I have read different accounts of how to proceed but this is what I think I should be doing (using SB Heavy 10" lathe - 4-jaw chuck and live center): with half the width of the wheels on the part (at the face of the bar near the live-center) use slowest lathe speed and plunge the tool to the depth of diamond desired, do not move tool until after at least one full revolution to be sure pattern does not overlap themselves. At this point should I or should I not keep plunging in after one revolution if my pattern is not at the depth I want? Once I am satisfied with the pattern engage the half-nuts for tool to travel towards chuck at .025 ipr? At the point on the bar where I want the pattern to stop do I just turn off the lathe or back out the tool first?
After knurling I will part the part off the bar and then drill both ends for the reamer and the ball bearing at the other.
Thanks for the responses.
