lowCountryCamo
- Jan 1, 2012
- Savannah, Georgia, USA
I am nearing the end of scraping a Rockwell 14 by 40 lathe minus the hardened bedways. I have scraped the tail stock base and got the top of the base parallel with the carriage travel within .0002" However because of the ram wear I had to add couple thou of paper shims under the tailstock in the front between the base and top to get ram parallel. Now I have tested height of TS to head stock and it is still .003" low however parallel. What is the best way to deal with this? I could add shims to front and back. I have read not to turcite under TS cause it won't lock well. What have you all done? Thanks, steve.
