conceptsmachine
- Jan 19, 2005
- DeSoto, IA
I'm trying to figure out if a piece that I'd like rapid prototyped could be 3d printed? It's essentially a 5 sided box , or a cover/lid, if you will. Basically all the way around is 3/8 wall thickenss.
Wondering what it may cost , if it can be made, or if I should just try to make it out of sheet stock. Any suggestions? There is also a bottom half and some inserts that go in the middle to house some items. I can make those easy enough. Maybe a 3d printer could make the entire unit, which would be about 10"x15.5x25.5
thanks for any info you can pass.
doesn't matter the material make up, as long as it's durable enough to hold up to minor stress, so im open to all prototyping methods within reason.
