Those of you that are machining your own remington700 receivers, are you cutting the rear portion of the action down to the remington size or are you leaving the receiver the full diameter across the top? If you are leaving it the full diameter, what one piece scope mounts are you using? Are you able to find some with a 20 moa base or are you making your own?
