Robert Bollinger
- Dec 3, 2014
- Florida
I am milling a .460 hex on the end of a shaft in G17 XY plane and it is .4615 I cannot get tool wear comp to work. The dealer's application engineer said machine will only read tool nose radius wear as a positive value. So we reposted the program telling the machine that a .250 end mill was .240 and put .010 in nose radius wear with the same result no wear comp. hex is now .4515 Anyone know how to get wear compensation to work when milling on a lathe. There is no spot for a D value as there is on a milling machine.
