challenger
- Mar 6, 2003
- Hampstead, NC-S.E. Coast
I have a Sheldon with a telescopic taper attachment. Everything seems in good condition other than there is binding at the last 20% of both ends. This causes the carriage to "crab". There are two potential sources of this binding. One is the small rabbit that slides over the bar that's on the taper at attachment and the other is the large gib/dovetail that is fitted into the main casting which is bolted to the carriage. The rabbit gib I have adjusted and found it to not be the culprit. This leaves the dovetail and tapered gib under the main casting. Is there a way for me to check and or a repair the wear in these two (or more) areas?
Thanks
Thanks
