I am working on a Challenger 1A618. I am not a Machinist by any means. I purchased it as well as a DoAll 13 lathe and a 113" Vertical bandsaw (the brand escapes me at the moment) basically at an estate sale. the previous owner was a bit of a tinkerer and a self proclaimed "Cobbler".
he gutted the control box, there is literally nothing inside the electrical box at all. He installed a 110/220v 1hp motor, running it on 110v so it was very under powered. and also installed a mill chuck and a second motor to run it, turning into somewhat of a mill, it was clearly a home made job but appeared to be pretty true, he only used it to cut keyways.
I have a couple questions and requests.
first can anyone provide some pictures of what is actually inside of the control box? I have the basic 20 page owners manual, but that only covers the basics of operation and maintenance.
I do not have 3phase if i keep it, as well as it would be easier to sell if wired for 220v so what would be a good motor to use to run it? the motor on it is 220v as well but i have not tried it on 220v yet.
also does anything go inside the base? it is the sheet metal base not the cast, this model didn't appear to come with the dust collector as the base is completely enclosed except for the door in the front. I was thinking of mounting the hydraulic pump and tank inside just to make it more of a self contained unit as well as not taking up as much floor space. would there be any issues with doing this? I have a sight gauge i can mount though the base so the level can be checked without having to go into the box.
I haven't gotten into checking the ways and everything out real good yet, they appear to be in good shape but i have not measured them, it came out of a High School so i assume it lead a fairly easy life, right now i am just cleaning the 15 layers of paint off, apparently the school painted it each year or two so there is many layers of paint on it in various states of pealing.
Thanks
Thanks
