Mickey_D
- Apr 18, 2006
- Austin, TX
I have some parts that I need to run on my L200EM lathe with the P200L control and conversational. The part is an aluminum adjuster ring with a 2" OD, some holes drilled and tapped around the perimeter, and a slight "nautilus" 360 degree feature in the middle. The easiest way to describe it is at 0 degrees we have a wall thickness of .25", at 180 degrees .24", and at 359 degrees a thickness of .23". Planning on cutting it with a 1/4" EM with a driven tool.
