Monomer
- Dec 11, 2006
- Detroit, MI
Greetings,
I've undertaken my first gun build. It's a Yugo RPK from a parts kit. Instead of building with a store bought receiver, I plan on bending from a flat. So far I've bent a flat up from AK builder 1.5mm RPK flat with the AK builder bend dies. I've yet to weld on rails, or drill front trunions. According to most: a torch to the fire control group pin holes is enough, but I'd much rather have a fully hardened example. I want it to last.
A few years back, I was gifted a kiln (one of three in the garage) I'm in the process of retrofitting a proper PID/Thermocouple to it.
My question is about metallurgy and hardening/tempering. I get a lot of different sources on what temp and times to use. The steel is 4130. Has anyone on here done this? Dispite the low cost, I'd rather not mess a couple of flats up! I want also to be safe about it.
I was planning on doing it like this: Full Heat Treat of AK Receivers - YouTube
I guess I just want more science behind the procedure. Not sure on the brine used, but I was planning on using used motor oil. Heat treat is all new to me, I would usually outsource this.
