I recently had the table ground on a surface grinder and it looks great, but I know they didn't grind the ways.
To check their work on my 4' x 3' surface plate, I just need to put the table on the plate and raise it up using 123 blocks so I can run an indicator under under the surface as well as over the ways. Also I need to put pins in the ways and use a micromiter to measure the distance there.
Is that the right way to do it?
