bellaireroad
- Oct 4, 2015
Is it safe to heat a bearing like this to 200°? Will there be any affect on the seals? Thanks
Amazing what you can find when you Google search questions.
SKF provides tips on troubleshooting bearing temperatures
SKF heaters for hot mounting of bearings and components
Fahrenheit, you're likely OK. Celsius, I'd say no.
Why not look it up at the nearing manufacturer'e website?
To be sure, ask Accurate what the grease and seal types are.
General purpose grease is typically rated for operation to 120C=250F.
See: http://www.skf.com/binary/68-99598/13238EN_GreaseSelectionChart.pdf
General purpose seals are typically made of NBR. This is rated for extended operation to 100C=210F and for short periods to 120C=250F.
See: Temperature limits. (The other materials that are typically used such as FKM generally have higher temperature ratings.)
The bottom line: if these are standard bearings and you are heating them for 20 minutes to install them, it's OK to put them into an oven at 100C=210F. That will expand them by about 0.0006" per inch of diameter, which should be plenty for slipping them over a motor shaft or similar.
Are you not living in the furnas called Texas? I thought it was always 200 there, at least in the sun
I just wrote the bearing Mfg asking this: I use a infra red hand held heat gun to test temp. Before that I used a wax temp melting pencil I never went over 180 degree's but my bearings were open and I used Iso Flex grease. Let the MFG tell us. Rich
Hello,
Can you tell me what temperature do you recommend that this bearing is heated on a bearing heated to slide onto a shaft? Do you supply a data sheet on the bearing grease? What is the maximum operating temp of the bearing? I have also attached a link to the form we all write and read in. A member asked the question.
https://www.practicalmachinist.com/...aping-and-inspection/heating-bearings-353131/
Thanks for your help
Richard King
Put your shaft in the freezer if you can.
Notice
