Mad man marine
- Dec 11, 2018
So. This is my first post. Been meaning to join this forum for a while but have been way to busy in the shop. Looks like tons of info in hand. Anyway. On my personal excavator I’m rebuilding the final drive hydraulic travel motor. One of the problems is on one side of the main load bearing ,bearings. The bore is about 3 thou to big so you can just barely spin the bearing race in it by hand. It’s a ntn cr-2256 bearing which is right around 5” od. I’m wondering if I heat up the casting just around that bore if I can then cool it reliatively quick to try and shrink it a touch? I guess my other option is to tig braze a layer inside and then chuck it up on my large face plate and re machine it to spec. Seems like an easy way to mess up an expensive part. I would just buy a used reduction housing but the parts for this 88 John Deere 70d are pretty hard to come by. So that’s pretty much out of the question. Sorry if this isn’t posted in the right area but .... anyway. I wanna say thanks in advance to anyone that chimes in with ideas or info. Thank you Ian Adair.
