DethloffMfg
- Sep 22, 2018
- Portland, OR
Does anyone here have experience with these compressors? I've been looking to upgrade my compressor for a long time and am getting close to pull the plug out of necessity. I am looking at a 3-phase 5HP compressor and I want it to be the correct fit that I don't need to worry about for a while.
I'm specifically looking at the 5HP, 3-phase, 80-gallon tank vertical, Industrial Plus Quiet Air unit.
5 HP Quiet Air Compressor, 3 Phase, 2 Stage, 80 Gallon Tank, Vertical
I have liked what I see from Polar Air. Sounds like they come with Leeson motors and the pumps are beefy. The Quiet Air 5HP model is rated at 60dB which is less than my small compressor I use to run my mill. The Industrial Plus variant has a belt tensioner, automatic drain, continuous-run feature and last time I talked with them that also upgraded you to a TEFC motor over their standard ODP style.
Anyone have experience with these? They aren't cheap once freight is added in. I don't want a cheap compressor that falls apart and it sounds like Atlas-Copco, IR and other big names aren't so good after getting sold out?
