I try not to recut the chips- I tend to use the mister with a fair amount of air to clean them out. The failure is on the tip, rounding it off and then burning it.Possibly cheap cutters- I tend to buy them for McMaster.
As a machinist, there are 2 things that will always kick your ass. Lack of rigidity, and a thrashed machine.
The good thing is that if you learn techniques to deal with these things, and can still make good parts and
hit decent tolerances you are going to be a fricken superstar when you get something that is rigid and square and
accurate.
Bridegeport style. Lets just talk about the rigidity, because that, right now is 90% of your problem, or at
least I'm convinced it is.
So you've got a floppy machine. I've got one too, I haven't used it in 12 years, but I have one, and I've used it, and I've made a lot of money on it.
First thing you need to do is pick your tools, and this is really easy. You can go with corn cobs, but that's old school. What you need is variable flute and/or variable helix endmills. You're floppy, you get chatter, you need to break up those harmonics, and that is what these endmills are specifically designed to do. They are awesome on a brick shithouse of a machine, but where they really truly shine, is on a floppy machine.
You're losing your corners.. Because you have a floppy machine. Corner rads. Simple enough.
Try some of these.
TITAN VI-PRO ENDMILL
or these.
1/2 Variable Flute End Mill with 1.25 LOC MariTool
Both of those guys are members here, and both of them will back up their product. *I'll* back up their products, neither one is going to screw you or sell you crap.
So now we are doing what we can with the tool to limit the harmonics and keep the corners from chipping..
I had a series 10 Acroloc... Is that laughter I hear?... 90% of the machine is pretty solid, its not a
monster, but its all box X,Y, and some of the Z, but it runs a Bridgeport style quill with a tool holder
interface that is just somewhere between pitiful.. disgusting.. and embarrassing.. Floppy doesn't begin to
describe it. Noodle-y would be more appropriate.
EVERY tough cut I made, even with the good endmills, busted a corner off first thing, and sometimes it took
the whole tool with it, or the busted corner wedged and screwed it all up. I would actually take a brand
new endmill out of the package and grind a big chamfer on one corner, and then run it. That really really
really broke up the harmonics and I could pretty much do what I wanted within the limitations of the HP
of the machine. It was pretty amazing.
There are some programming techniques that I've used on a CNC knee mill and the Acroloc that can make the machine
seem more rigid than it is. If your interested, I'll expand on that, I probably will anyways, but right now,
I've got to make some phone calls and feed the pups.
