beckley23
- Feb 19, 2003
- Louisville, KY, USA
Mounted a DRO on the CY this week, no major problems, except that I've a cable extension coming in for the X axis. The cross slide did present a couple of solvable problems with its construction. The blister on each side of the cross slide for the compound rest swivel, and the fact that the ways are lower than the carriage wings. With this construction glass scales would be a problem, because they have to be supported at each end, but with Newall scales that are short enough, they can be supported at one end. Newall even supplies a special mounting block for the Microsyn scale for this type of mount.
In the pictures that follow, you can see that it's a pretty tight fit, and I've had to move the mount once, actually I switched to the block from the pillar mount when I almost crashed the pillar into the carriage wing when retracting the cross slide to its outer most limit.
The socket head cap screw is the hard stop for the tailstock.
Harry
Harry
