mattthemuppet
Stainless
- Apr 22, 2016
- San Antonio
hi all, working on the last bits'n'pieces on my 1929 SB9 (382R). When I took the headstock apart for cleaning and fitting a new belt the front/ chuck bearing had a brass shim (0.0035" thick) around it. Both bearings are one piece bronze with removable top caps with oil cups. When I tested spindle deflection it was in the 6-7thou range, using a dial indicator in a holder stuck to the bead or gear box and a 2ft 5/8" bar. With the top caps removed there was a clear gap around the bearing, between the headstock casting and bearing, and it was easy to move it back and forth perpendicular to the spindle.
Once I added the shim back, plus a thin shim on top of the rear bearing, I tightened the front bearing cap down to tight'n'a little bit, then used the DI on the gear train end of the spindle to torque the rear bearing cap bolts down until deflection stopped decreasing.
Numbers front and rear are 0.0012-0.0014" using the prescribed method. A hand spin of the spindle pulley gives 1/2 a rotation (no chuck mounted). I then ran it at 300, 500 and 1000rpm each for 5 min or so. No issues I could find, bearings didn't heat up that I could tell. Oil quite happily made it out of the cups, through the bearings and out the bottom.
Is that amount of deflection ok? It's more than recommended (0.0007 to 0.001") but I don't want to over tighten the bearings either.
