10" gearbox
Results 1 to 4 of 4
Thread: 10" gearbox
    Jun 2017
    Mississippi
    28
    16
    Default 10" gearbox
    Working on a single lever tumbler and the lever is worn where the sprocket shaft goes through. What is the cure for the slop?
    Jan 2019
    North Carolina
    229
    26
    40
    You mean the bore that holds the shaft for the idler gear, correct? If so, it came in two ways. One way had a thrust bearing the gear rode on and the other is like you have, the shaft itself spins whilst the gear is keyed.
    In short there isn’t an “easy” fix. It depends on what tooling you have and what your capabilities are. I’d suggest either broaching it and making the new shaft for the gear to spin on while it’s affixed to the tumbler; or reboring the hole and making a new larger shaft. You could also sleeve the bore but I’d expect your shaft is worn as well.
    I’ve made several replacement shafts, idler gears, and main pinions for members here. If you don’t have the tooling to do it you can send me your tumbler arm and I can do the repairs for you.
  3. Likes blacksmythx liked this post
    Sep 2010
    moscow,ohio
    6,178
    623
    2010
    i can certainly vouch for Stephen.....these are some beautifully executed parts....just opened the package today, almost dont want to use that pinion shaft,shame something that nice wont be seen once its installed....almost criminal even...
    pic doesnt come close to doing them justice- this is quality stuff.
  5. Likes blacksmythx liked this post
  6. #4
    Jun 2017
    Mississippi
    28
    16
    Yes, that's the right one. I was hoping I could squirt some JB weld in there or hammer in a piece of Sprite can or something. No I not very equipped for this repair nor do I have the skills required, expect a PM while I consider my optins.
